MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
ISM330DHCX: accelerometer usable bandwidth
Hi, at my parttime job we are using the ISM330DHCX in an industrial sensor for measuring acceleration, gyro and inclination. In the description for ISM330DHCX is stated, that it can be also used for vibration measuring. In the datasheet (p.50/167 Tab...
APozd.2 by Associate
  • 2794 Views
Audio USB interface for IM69D130 MEMS Microphones
I recently bumped into an audio USB interface which might fits my needs : the STEVAL-MKI138V1. Indeed, I want to get the audio signals of 4 MEMS IM69D130 microphones onto my PC on Audacity, through a USB audio interface like the STEVAL-MKI138V1. Howe...
Do IMP23ABSU have only MEMS transducer or with any amplifier?
Hello, I want to find some MEMS transducer for microphone for testing our readout IC for MEMS microphone No matter with single or differential output, but the product that I need is the transducer without input buffer, output amplifier and other. Is ...
JKim.38 by Associate
  • 989 Views
  • 0 replies
Resolved! Where to download Unicleo-GUI?
Hello,I have found informations about Unicleo-GUI, and I would like to test it. There are many informations on ST page, but I could not find any link to download it.So where can I download it?Thank you
ANauz.1 by Senior II
  • 3569 Views
  • 5 replies
Resolved! Cannot make accelerometer LIS2DU12 in Sensor.Tile Pro working ?
Hello, I cannot make the LIS2DU12 working in the Sensor.Tile module. I followed the instruction in the AN5648 but I get random values for X, Y, Z. At first, I'm trying to get the readings in normal continuous mode without FIFO. I can connect the devi...
jea74 by Associate III
  • 1838 Views
  • 1 replies
using STEVAL-MKI221V1 adaptor on STEVAL-MKI109V2
Hey, I wanna use MKI221V on MKI109V2, the sensor datasheet says that it's - "Compatible with STEVAL-MKI109V2 by changing resistor settings". Couldn't find any references to what resistor settings are needed and how to implement them, any help would b...
Lev_G by Associate
  • 1089 Views
  • 0 replies
Resolved! Is license needed to use MotionAC libraries
Hi,I am working on project using ZephyrOS and I am trying to link in and use some of your motion libraries.I have successfully linked but the call to MotionAC_GetLibVersion() is returning zero. Looking at assember in my debugger a variable is being t...
capacitive touch with brass metal
Hi,I want to design a capacitive touch application with a brass metal plate. So, i need a sensor that is suitable with brass metal. Is there any advised product for me?
er3481 by Senior
  • 1360 Views
  • 1 replies
