STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1504 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 572 Views
  • 0 replies
Resolved! Retarget scanf on STM32G070RBxx Cortex M0+
(originally a reply to https://community.st.com/t5/stm32cubeide-mcus/retarget-printf-on-stm32g070rbxx-cortex-m0/td-p/720883) Hi @Andrew Neil,For the scanf do we need to make any other change?My read function is-  int _read(int fd, char *ptr, int len)...
AVerm.4 by Associate III
  • 4237 Views
  • 9 replies
  • 4 kudos
Resolved! STM32L552 Breakpoints won't work
Hi, I just got my board STM32L552 and currently am setting up development environment for it. I'm testing the board with an example project 'CORTEXM_InterruptSwitch_TrustZone' and the code works well, however, I'm not able to set breakpoints for debu...
How to run code and view serial on Nucleo board
Hello,I am trying to count how many clock cycles pieces of code take to run on my Nucleo board. I am using the following code for timing: start_cycles = DWT->CYCCNT; // dummy code end_cycles = DWT->CYCCNT; diff_cycles = end_cycles - start_cycles; pri...
Resolved! Retarget printf on STM32G070RBxx Cortex M0+
Hi,I'm trying retarget printf. My uart_write function is working correctly and i'm able to see character on Teraterm.But when i try to use printf it is not working. i even tried semihosting to execute printf but it fails. i'm attaching the screenshot...
  • 10294 Views
  • 22 replies
  • 5 kudos
STM32F407G-DISC1 unable to be found on STMCube IDE
Hi, I'm having trouble when debugging the STM32 project. The board was connected to my laptop, however, on the IDE I can not find the option to debug on the target board. I bought this board a month ago and debugged it only a few times before.Please ...
Nhat by Associate
  • 1185 Views
  • 1 replies
