STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 232 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4076 Views
  • 0 replies
  • 3 kudos
Resolved! Sub ghz
Stm32l010r and s2lp using x cube sub ghz , for custom board just for coding only gpio button status, there are plenty of error, by solving all those 4-5 errors remain and their resolving method is to complete change of middleware files or some code l...
SL C.1 by Associate
  • 135 Views
  • 1 replies
Resolved! STM32WL30XX PCB Antenna Design
I need support for the design of STM32WL30XX PCB Antenna. Are there reference designs available for the PCB antenna?Specifications:Two layer board Output power 10dBm in the 868MHz band.
stm32wb5mm-dk with SAI interface
Hi, I want to acquire an audio signal from the microphone IMP34DT05 which is connected to the SAI interface of my STM32WB5MM-DK demo board in this way: L/R -> VDD; CLK -> SAI_CK2; DATA -> SAI_D2.The part number I chose is STM32WB5MMGH6TR in STM32Cube...
JayanthR by Associate II
  • 316 Views
  • 4 replies
