Jul 10, 2025 12:59 PM UTC
lora p2p
"Can someone please check this code? It's for normal LoRa point-to-point (P2P) communication. I’ve attached the file with this post. The problem I'm facing is that a software interrupt is supposed to occur every second and trigger my scheduled task — but it's not happening. Please help me fix it."
STTwo-32
STTwo-32Best answer
Aug 5, 2025 9:40 AM UTC
Hello @avinashkumar
I suggest you have a look at this tutorial. It should help you for this implementation.
Best Regards.
STTwo-32
Andrew Neil
Jul 10, 2025 1:07 PM UTC
STTwo-32
STTwo-32Best answer
Hello @avinashkumar
Best Regards.
STTwo-32
