2025-06-18 4:59 AM
Good day
I am designing a a PCB using the STM32WL5MOC module and need some help selecting an appropriate buck-boost converter and designing a battery charging circuit using a 3.7v rechargeable battery. Would it be possible to direct me to an example schematic in order to do so. I am new to hardware design and this will significantly help.
Than you in advance !
2025-08-04 3:23 AM
Hello @HKhan.4
Unfortunately, there is not such a design that does include a buck-boost converter and a battery charging circuit. For that, i suggest you contact a HW designer and a power expert to help you implementing this design.
Best Regards.
STTwo-32
