STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
STM32WLE5JC code snippet for simple Lora RX/TX
Hi all. I'd like to write a simple bare-metal application for STM32WLE5JC. Could you provide snippet code for STM32WL (core + radio) initialization and simple RX/TX Lora Packet ? Thanks Olivier
OFauc.1 by Associate II
  • 3851 Views
  • 5 replies
  • 2 kudos
Regarding RTC in WB55?
I am working on smart watch and I have been using STM32WB board, The bluetooth is communicating with the Mic and it is working fine, I want to display, Date and time on my ST7789 display and I want to know how I can display, I am using BLEPeripheral ...
NY L.1 by Associate II
  • 769 Views
  • 0 replies
How can I validate the LoRa MIC value on the NUCLEO-WL55JC1?
Hi everyone,I am trying to connect a NUCLEO-WL55JC1 to the TTN network. I have specified the device EUI, app/join EUI, app key and network key in the se-identity.h file. The debug output of the board confirms that the values correspond to the values ...
moatjon by Associate III
  • 3531 Views
  • 4 replies
Bootloader for STM32WB55
I have written bootloader for F0 and F1 series. These are pretty straight forward and lots of flavors available on Github. However I cannot adopt the same strategy for the WB55. The reference documents on memory mention a standard bootloader and an O...
PGogt by Associate III
  • 2597 Views
Resolved! HW_TS timing is different when appe_Tl_Init(); is called
I have written an app using the sequencer and time server. My app selectively runs or doesn't run the BLE stack by calling or not appe_Tl_Init();I use HW_TS to generate delays. When I don't run the appe_Tl_Init function my timing is correct. when ...
LHarm.1 by Associate III
  • 1588 Views
