NUCLEO-WBA25CE1 "Bootloader limitation"
ctrois
As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1.
Please refer to "Workaround" section if you are facing this limitation.
Issamos
Lead III
Hello @ctrois
Thank you so much for this information. I think it will be better and it will be easier to find if you publish it as FAQ.
@Laurids_PETERSEN
Best Regards.
II
