STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
Resolved! STM32CubeIDE only generates Dual-Core structure
Hello,I am working with the STM32WL55CC (48-pin package). When I imported the official STM32CubeWL example projects from ST, I noticed that they provide both SINGLE CORE and DUAL CORE versions. But the board that these examples are listed under STM32...
Resolved! CubeMX v6.15.0 can't open old ioc
Hello,I recently updated my CubeMX version from v6.14.1 to the latest, and am no longer able to open the .ioc file. Selecting "continue", results in attempting to unzip DB.6.0.141.tar.bz2 where it hangs until failing.Selecting "migrate" results in th...
bryanwebb by Associate II
  • 1193 Views
  • 7 replies
  • 3 kudos
Rdp = 1, locks backup register
I’m working on an STM32WLE5 device and I’m facing a reproducible issue when enabling Read-Out Protection level 1 (RDP = 1). When RDP = 0, everything works as expected: i can write/read RTC Backup registers, my initialization sequence behaves correctl...
Resolved! B-WL5M-SUBG1 (STM32WL5MOC) current consumption too high
Hello,We have an issue with the B-WL5M-SUBG1 evaluation board: The idle current consumption is higher than expected: 89 uA (vs. expected: 1-2 uA) after joining (OTAA) successfully.Board: B-WL5M-SUBG1Firmware: STM32CubeWL/Projects/B-WL5M-SUBG1/Applica...
JBive.1 by Associate III
  • 3626 Views
  • 7 replies
  • 2 kudos
