STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
STM32WL55 lorawan endnode example
Hello everyone,  i am developping a project using STM32WL55 lorawan and when i try to send a message to the gateway and server , the first 10 to 15 messages arrives empty with no data and after that the messages arrives normally without any problem. ...
Resolved! STM32WBA antenna matching
Hello,I am working on a new design using the STM32WBA52CGU6. Is it possible for me to use the MLPF-WB55-01E3 to match the antenna impedance? Or what is the output impedance of this MCU?Thank you in advance.
dryet by Associate II
  • 4446 Views
  • 3 replies
STM32WB project architecture
Hi,I want to ask an infomation about how to correctly insert some custom code in the BLE_Custom example project. I would like to modify the code in order to perform some operations to read a sensor connected to the P-NUCLEO-WB55 through I2C and than ...
Resolved! STM32WB works with Custom BLE, rtos and stop modes
What would be the best way to develop firmware on the STM32WB with customized Bluetooth and using an RTOS?When using FreeRTOS, I’m unable to generate custom BLE code in CubeMX, and I’m having difficulty controlling the device’s sleep mode. It seems t...
STM32WBA52 BLE Support
Hi @STTwo-32Given that the distinguishing feature of STM32WBA52 is BLE and considering that connectivity applications support was removed since SDK V1.2.0, could you please clarify if this implies that there will be no further support for connectivit...
