przemyslaw jakobczak
Problem with handling multicast frames Lorawan
  • July 8, 2024
  • 1 reply
  • 651 views
I have a problem with handling multicast frames. I think it's a server side problem and how to read multicast frames in the lorawan stack? The same as unicast frames? I added support for multicast frames in TTN according to https://www.thethingsindustries.com/docs/devices/configuring-devices/multicast/. Is there an example? Multicast frame support with server?
Best answer by STTwo-32
Hello @przemyslaw jakobczak
For this request, you may need to refer to the Server owner on his community. It should provide more details about that.
Best Regards.
STTwo-32
1 reply
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
