STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Hi I have been using 480x272 Resistive display in my TouchGFX project The project has been created using CubeMx for STM32F746G discovery board controller We have used the stm32f746G board display configuration for Resistive display.
While running of resistive display,some oscillations on the texts appeared on the screenSometimes noise came on display.I have attached the video that shows the display noiseCapacitive touch parameters(Vsync,Hsync) have been used for Resistive touc...
STM-User by Associate II
  • 1339 Views
  • 1 kudos
Touch on STM32F469 Discovery is not working in example programs, is there any hardware/driver update to know about?
Hi! I programed my usual code to the newer batch of STM324F69 Discovery but the touch capability of the screen is not responding. Out of the box the example program works fine, but when i Program the button example the touch doesnt works. This same b...
Simple SPI Display, no TFT, no Touch setup.
I am currently working on a custom STM32h743xx board with a small (128x64) monochrome OLED screen that uses the SSD1309 SPI driver for communication. This setup is very simple but vastly different from the setup of most examples. From my understandin...
ALiar.1 by Associate
  • 2083 Views
Resolved! Can't recognize numbers with Unicode
Hi, I'm building a program which has a part that is similar to the "Flex Button Example".In my case I've got a problem with Unicode. My program works the same as the image above. When I reach to number 24, 26, 28, 29, this is what it shows:This is my...
DCost.1 by Associate II
  • 1719 Views
STM32F769I-DISCO SDRAM
Hello.I want to know how SDRAM is used in TouchGFX. Where can I find information?Does SDRAM have an address to access?I would like to check the operation of SDRAM. How should I check the read / write?Thank you.
Ebun.1 by Senior
  • 1055 Views
Where is the "Configuring-STM32F746G-DISCO" page?
Where is the "Configuring-STM32F746G-DISCO" page? I used to see this topic in the help center, but now I can't find it. The previous URL was "https://touchgfx.zendesk.com/hc/en-us/articles/360019884752-Configuring-STM32F746G-DISCO". Now this link can...
CGong.1 by Associate II
  • 4824 Views
  • 8 replies
Frame buffers
Hello....Am currently working on STM32L4R9AI-EVAL board and i have so many doubts about frame buffering....1.when we have to use single frame buffer,when we use double frame buffer,and partial frame buffers and rendering time is less for single buffe...
prathima by Associate II
  • 6763 Views
  • 27 replies
