MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
LSM9DS0 accelerometer Big/little endian data selection
Posted on February 11, 2014 at 15:29I can't find where to set Big/Little endian data output in LSM9DS0. It (BLE) is in register 0x23 in LSM303DLHC.  Can anyone give me a help please? Thank you very much for your kindly help.  #lsm9ds0
huiyan by Associate
  • 690 Views
  • 0 replies
A3G4250D starting problems
Posted on November 22, 2013 at 14:19Hi everybody,I am trying my first steps with the A3G4250D MEMS Gyroscope. Unfortunately, I did not manage to get useful measurement information yet. What I want to do is the following: sample the angular rate wi...
karsten by Associate
  • 2290 Views
L3GD20 DRDY stability
Posted on February 06, 2014 at 09:59Hi, I'm testing L3GD20 with SPI on my small test board.  It looks like OK so I can get gyro data and DRDY signal with 760Hz. But when I monitor DRDY signal with my oscilloscope, it has a jitter sometimes.  The dif...
sawa by Associate
  • 765 Views
  • 0 replies
A3G4250D data conversion
Posted on February 06, 2014 at 04:50Hi, I am evaluating the A3G4250D gyroscope, could any one give me formulae or steps to convert the gyro and temperature data into deg/sec, degC respectively. Regards, Kantha
Start-up state of L3GD20 and SPI bus
Posted on January 10, 2014 at 20:15On power-up, does this gyroscope come up in operating, sleep, or power-down mode (i.e., when all SPI peripherals in my instrument are powered up by a common bus, how much is the gyro drawing?The datasheet says that...
LSM9DS0 4-wire SPI communication
Posted on October 12, 2013 at 08:27hi,guysI'm working on LSM9DS0 with STMEVAL-MKI109V2,using 4-wire SPI communication?read gyro's WAI reg is ok if keep CS_G=0 and CS_XM = 1 after EVAL board power on, but if CS_G=0 after CS_G=1 and CS_XM = 1,read WAI...
poa by Associate
  • 1513 Views
  • 3 replies
