MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Got data from LSM6DS0. Next step.
Posted on August 09, 2016 at 19:00I’d like to understand some basics, how to work with the device. I read the data from the chip and see it on terminal but I don’t understand how to practically use the data. Also when I use ACC data and when I use G...
LSM6DS3 Accel/Gyro ADC Resolution?
Posted on March 29, 2016 at 08:06Interested in purchasing the LSM6DS3 device. Studied the datasheet carefully, and there is no information on ADC resolution for the accelerometer and gyro. This is odd considering this is a key spec for any prospecti...
LSM6DS3 cross axis sensitivity
Posted on April 14, 2016 at 01:24Does anyone have information on the LAM6DS3 cross axis sensitivity? I cannot find this on the data sheet, when this is supposed to be a standard spec on other similar products. I contacted online support and they ask...
kh by Associate
  • 1036 Views
  • 1 replies
LSM6DS3 Resonance frequency
Posted on April 14, 2016 at 09:52Hi everybody, I'm using LSM6DS3 and I need to know its resonance frequency. In the datasheet this information is not present. Thanks in advance #lsm6ds3-resonance
massimo2 by Associate II
  • 987 Views
  • 1 replies
IIS2DH Temperature sensor data
Posted on August 07, 2016 at 13:03Hello,1.according to section 2.11 Temperature sensor :should i read both OUT_TEMP_L (0Ch) & OUT_TEMP_H (0Dh) ?the data is stored only in OUT_TEMP_H (0Dh) ?2.the data i get using OUT_TEMP_H (0Dh) is too low (10C-13C)...
amirma by Associate
  • 1068 Views
  • 1 replies
hts221 returns 0xAE
Posted on August 04, 2016 at 10:48HTS221 after read all humidity registers final value always 29.0% and not changed in time. All data register contain 0xAE values. ST firmware driver for HTS221 also returned 29.0% and 0xAE registers values. Connecti...
LSM9DS0 magnetometer
Posted on August 04, 2016 at 11:54Hi,I'm working on lsm9ds0 and spi with a stm32f4. The accelerometer and gyroscope work successfully on my device but since a few days, the magnetometer seems to get random values. For test, gyroscope is in power dow...
theo2 by Associate
  • 762 Views
  • 0 replies
LIS331HH power consumption
Posted on July 27, 2016 at 07:20Hi,I try to get power consumption about 10 uA using LIS331HH in low-power mode (power supply voltage 3V). But I've got 23 uA average power consumption in low-power mode (0.5 Hz data rate).Working cycle: sleep (power c...
