MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
MotionFX output stuck at zero on STM32L476 Discovery
Hi everyone,I am struggling to get MotionFX (9-axis sensor fusion) working on an STM32L476G-DISCOVERY board using the onboard LSM303C (Acc/Mag) and L3GD20 (Gyro).The Problem: Despite the library being initialized and updated in the main loop, all out...
Resolved! Lis3dh : X Y & Z value and Threshold configuration
Hello,I have two technical questions regarding the lis3dh accelerometer behavior and interrupt configuration.1) Are the values I read from the LIS3dh  in m/s²????  Exemple :::Accel [LIS3dh] 28807220458ns (-7.300384, -1.942303, -5.712095)2) Interrupt ...
ASREB by Associate II
  • 160 Views
  • 1 replies
  • 1 kudos
Accelerometer zero-g level change over time
Hi,I am using IIS2ICLX MEMS accelerometer in an IOT device.The IIS2ICLX is soldered on a PCB that sends data to internet every 10min.To measure the zero-g level of both x and y axis, I suspend the device from the ceiling so that the PCB (and the acce...
Resolved! ISM330DHCX Measurement
Hi. I have been looking at the internal operation of MEMS devices and am looking for information on how this sensor takes the reading from the mechanical parts. I am trying to find out if this sensor uses capacitive sensing or frequency drift and tim...
jhurd by Associate
  • 100 Views
  • 1 replies
Resolved! LSM6DSV320X sensor not responding
Hello everyone. I would really appreciate if someone could help me sort out a really annoying issue i have with a new STM32WB5MMGH6 based board i made.On this board i have two sensors connected to the same SPI interface (hspi2) with different CS pins...
Screenshot 2026-04-15 at 14.24.40.png Screenshot 2026-04-15 at 14.25.41.png Screenshot 2026-04-15 at 14.29.50.png Screenshot 2026-04-15 at 14.31.57.png
yaxsomo by Associate III
  • 264 Views
  • 3 replies
  • 2 kudos
ims330dlc Gyro signals
Hi Does anyone know how to stabilize the gyroscope and accelerometer signals. I am getting signals back but I am trying to move a radio button on a bullseye and can't seem to smooth out the signal. I am using I2C communications.
ODR rate on ISM330DHCXTR
Hello, I'm using (ISM330DHCXTR) accelerometer to calculate the phase difference between two axes to measure the movement of a system. configured ODR at 6.6 KHz and measured the operation frequency of the system which has a 10% error while measuring t...
