MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
How to implement callbacks to my i2c code for the VL53L3CX
Hi,I am implementing the VL53L3CX in a custom design and am trying to get the API working. The documentation says that there is one sample included in the API that shows how to call it. It is not present in the supplied API download (VL53L3CX_BareDri...
Kevyk by Associate
  • 1033 Views
Connect LSM303AGR Interrupt Pins, really necessary?
Hi.Excuse me if this query seems very silly, I am designing a schematic and it will take the integrated LSM303AGR because I need to read accelerometer and magnetometer data by I2C.What happens if I leave the accelerometer interrupt pins (INT_1_XL and...
Gustbel by Associate
  • 1716 Views
  • 3 replies
IIS328DQ I2C Setup
IIS328DQ CS, SCL, SDA, and SA0 pins are having internal active pull up. If I were to use I2C communication, do I need to connect CS pin to high? Since it is already had internal active pull up, I don't think that we still need it....please confirm.
KTeng.1 by Associate II
  • 1085 Views
  • 1 replies
IIS328DQ PCB Design Guidelines Unclear
Not quite clear about the statement " "Pin 1 Indicator" unconnected during soldering " as mentioned in the datasheet. Can someone elaborate on this?In the Recommended Land and Soldermask design, the statement "PCB THERMAL PAD NOT TO BE DESIGNED ON P...
  • 902 Views
  • 1 replies
Is it possible to use an external clock source for lSM6DSL?
Hi, I am reading FIFO from a couple LSM6DSL IMUs, but the FIFO generation speed seems a bit different even if all of them are in the same configuration. I am suspect it is the different of the internal clock source. Does anyone know if it is possibl...
jb by Associate II
  • 2007 Views
LPS Pressure-sensor: model differences and part naming scheme
I am looking for "cavity"-type pressure sensors like the LPS27 or LPS33 but I am having a hard time finding out what the differences between the models are. For the stm32f series the online documentation includes a great comparison chart of the diffe...
JHenn.1 by Associate II
  • 2574 Views
Sampling frequency of LSM6DSOX
Hello,I am measuring acceleration with LSM6DSOX.On account of unknown frequencies in measurement I want to know the relation between ODR and sampling rate.I found in https://www.st.com/resource/en/application_note/dm00571818-lsm6dsox-alwayson-3d-acce...
amuel.1 by Associate II
  • 1141 Views
  • 1 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
