MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Where can I find STEVAL-STLCS01V1 's external layout?
Hello,I would like to include this board on a custom design but I was unable to find it's pads, connectors layout.There's nothing in the datasheet and only gerbers are available... :(Where can I find this information?ThanksJulien
JulienD by Senior
  • 1019 Views
  • 1 replies
lis2ds12 Bypass to FIFO/Stream example
My test:I want to set up the FIFO for bypass->stream, and then just move (shouldn't have to be a violent shake) the PCB that has the lis2ds12 on it and see the FIFO have data. I'm only able to detect violent shaking... could you please advise / sugge...
ATemp.1 by Associate II
  • 1283 Views
  • 1 replies
Resolved! LSM6DS33 -> Bulk read FIFO
Hello,I am using the FIFO to read the gyroscope and accelerometer data from the LSM6DS33 using a Raspberry Pi. It is connected over I2C at a frequency of 400kHz. Currently it takes between 4-7 seconds of constant reading to empty out the FIFO and by ...
MKama.2 by Associate
  • 1304 Views
  • 1 replies
Resolved! LSM9DS1 FIFO usage
Hello, I tried to use FIFO in way to count data ready . My idea to count sample and if it is a 32 sample in FIFO I read all at once. As far I understand, according by datasheet "Accelerometer and gyroscope multiple reads (burst)" Page 21Data stores ...
Zaren by Associate
  • 1333 Views
  • 1 replies
LIS2DW12TR not returning values
I am trying to run the ACCEL 10 CLICK based on the LIS2DW12TR on MicroPython on i2c protocol.A perfectly working code of the ADXL345 is https://github.com/DFRobot/micropython-dflib/blob/master/ADXL345/user_lib/ADXL345.pyTaking this as a reference I t...
YBend.1 by Associate III
  • 2254 Views
  • 10 replies
Resolved! How to configure the embedded pedometer inside the SensorTile.box (STEVAL-MKSBOX1V1 ) to be less sensitive?
Greetings,I have been working on the SensorTile.box and specifically the pedometer functionality (worn on wrist) for a while now and I am stuck right now.I want to optimize the algorithm to reliably count steps. To achieve this, I began optimizing it...
KWern.1 by Associate II
  • 3686 Views
  • 6 replies
