MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! temperature impact over gyroscope zero-level offset
Hi,I'm using the LSM6DS33 MEMS and found that in different temperatures the zero-level offset of the device gyroscope changes significantly.I recorded several recordings while the device is static, and found that consistently when the temperature inc...
MSham.2 by Associate II
  • 3911 Views
  • 4 replies
Resolved! Problem programming the sensortile with Nucleo
I have recently got a brand new Sensortile and a nucleo L476RG. I checked if the tile was working by connecting the tile to the cradle expansion board (STLCX01V1) and using the bluetooth app from ST (STBLESensor). The system worked and I could view d...
SSaha.1 by Associate III
  • 1737 Views
Resolved! Always getting ERROR when reading MLX90393 data.
Hi,I try to use MLX90393 with my STM32-F4 DISC board on SPI2. I can communicate with it, read and write non volatile memory, he responds to me.The steps that I'm doing are:Go to Single Measurment mode ( 0x3F )Send Read Measurment command ( 0x4F) Read...
bmak by Senior
  • 2406 Views
  • 3 replies
How to get the LSM9DS1 recommended power-up sequence?
Hi, I am reading the datasheet of LSM9DS1 and it says that there are two times (rise and wait) you should respectI was thinking in a sequencer IC but if we see the schematic of the LSM9DS1 evaluation board (STEVAL-MKI159V1) it does not use any kind o...
Resolved! How to calibrate tap sensing (LSM6DSM)
Hi, I have been able to get this sensor working, but the issue is that tap/double tap is really, really insensitive. Maybe its the plastic case of the unit, I do not know. I did the tap detection as in example:https://github.com/STMicroelectronics/ST...
HSund.1 by Associate
  • 1405 Views
  • 1 replies
