STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1429 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
Resolved! How Can I define a SDRAM usage in the Script Linker.
Hello, everyone:​I just migrate my development job from MDK to STM32CubeIDE. But I've got a little problem, details as follows:​1.environment STM32H750 + SDRAM(FMC), with bootloader in the AXI flash,but app was copied from spiFlash to AXI SRAM by ...
BTang by Associate II
  • 6425 Views
  • 4 replies
  • 2 kudos
STM32CubeIDE Cannot run program "gdb": Launching failed
I'm sure it's something silly and I can't believe I'm the only person who has seen this message but searching this site doesn't yield any clues. Can someone point me to what I am setting up wrong, presumably in the Debug Configuration menu ?
MikeDB by Lead
  • 1494 Views
  • 4 replies
Questions about coding style
Hello,I want to get the coding style of the SDK so that my code is consistent with the style of the SDK.Can you provide the appropriate configuration file?
Bug: STM32CubeIDE deletes files on Code Generation
STM32CubeIDE v1.0.1 deletes all my project files when I'm generating code with the integrated CubeMx. This only happens when theres a wrong path set in settings under firmware update.It then shows me the following error. When I then click on OK, I se...
thejc by Associate II
  • 2318 Views
  • 3 replies
How to compile example packet X-Cube-SPN8?
Hi, I am trying to manage a BLDC motor using the P-Nucleo-IHM001, so NucleoF302R8 and X-Nucleo-IHM01M1.I would like to upload the firmware version with the example X-Cube-SPN8.When I launch the building, it gives errors due to a different path, that ...
