STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1427 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 558 Views
  • 0 replies
STM32H7 dual core debugging
What is ST's response to this document and the fact that I am witnessing such behaviour (see image) ?? Was there simply an error in this document? I was following the doc only to be frustrated by M4 hitting a brick wall with SIGTRAP, there is mention...
LBeau.1 by Associate III
  • 5707 Views
  • 10 replies
stm32H474I cannot debug
I just got a STM32H747I-DISCO board. When I try to debug it and load the code to it by using its internal ST-Link and STM32Cube IDE. It says : "Break at address "0xa05f0000" with no debug information available, or outside of program code." And when t...
GunkutA by Senior
  • 4352 Views
  • 10 replies
  • 1 kudos
STM32cubeide gdb st link flash erase error
helloi use stm32cubeide 1.4.0 and cube programmer 2.5.0 i want to st link gdb server​https://community.st.com/s/question/0D50X0000BD4BDRSQ3/error-failed-to-erase-memory​The same symptom appears even if option byte is set and flash is deleted.​The a...
Ykim.4 by Associate
  • 773 Views
  • 0 replies
Disable Readout Protection from STM32CubeIDE Before Programming
I know that STM32CubeIDE calls STM32_Programmer_CLI.exe in order to program the chip, and I know that I can get STM32_Programmer_CLI.exe to disable readout protection on the chip by passing it a --readunprotect parameter, but how/where in STM32CubeI...
Ddu P by Associate III
  • 3031 Views
  • 3 replies
List of problems found by a newly CubeIDE user
I am a new CubeIDE user working on a new MacBook Pro. Transitioning from TI, where their IDE pretty much works, has been troublesome. I've encountered a number of problems I want to tell you about. I've found work arounds for some of them and just tr...
