STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1407 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 556 Views
  • 0 replies
STM32CubeIDE and UHD/4k screen
Hello,I know that these questions are far too easy for this forum, but a few days ago I destroyed all of the IDE settings several times when I tried to change these settings.First of all, the platform and environment used: Ubuntu Linux 20.04.2 and th...
I have a problem with USB working properly - USB CDC (Virtual Com Port) with CubeMX HAL after disconnecting the USB cable and connecting again.
HelloI have a problem with USB working properly - USB CDC (Virtual Com Port) with CubeMX HAL after disconnecting the USB cable and connecting again.For the test I created a project similar to the one presented here - https://www.youtube.com/watch?v=A...
Timer 8 issue in Cube IDE V1.5.0
When generating Code for STM32H753IIKx I recently stumbled across unexpected behaviour in Cube IDE V1.5.0. I'm using the processor Pins PH13-PH15 in order to output a PWM Signal from the N-Outputs of Timer 8 (CH1N1-3). However no correlating signals ...
DWeb_2 by Associate III
  • 1820 Views
  • 4 replies
Resolved! Bug in STM32CubeIDE?
Hi,I have a counter incrementing as:if (condition == TRUE) count++The counter is initialised as:int count = 0;I would expect that the counter would increment by '1' every time the condition is 'TRUE'. And this is in fact the case when I'm steppi...
NGalin by Associate II
  • 1280 Views
