STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1431 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
Resolved! u_printf_float - where to set for C_Linker in STM32CubeIDE?
When I compile, I get the following error: The float formatting support (-u_printf_float)is not enabled from linker flagsI can't find Linker flags/Options/Settings for C - just for MCU G++ Linker. When I chose the option, it still didn't remo...
MFend by Associate III
  • 19607 Views
  • 19 replies
  • 1 kudos
Could you show me the C data type documents in STM32CubeIDE? I want to know the data type of the GCC compiler, but I failed to find the related documents. below figure is that I found in another brand IDE.
I use STM32CubeIDE 1.9.0, the chip is STM32G474, I want to know the data type of the GCC compiler, but I failed to find the related documents. below figure is that I found in another brand IDE.Could you kindly help? Thanks!
kaka.zhuo by Associate II
  • 2759 Views
  • 1 kudos
Resolved! Even after building code with optimization level -0s. There is no change in size, it just get adjusted with .text and .data.
I am facing issue of memory with Stm32L432xx, So i tried option of increase optimization level from -01 to -0s.But observe no change it just reduce in .text section... but it increased in .data segment. ultimately value is same and issue is continueB...
PSola.1 by Associate
  • 3258 Views
  • 7 replies
Resolved! Separation of STACK and HEAP
Hello,I have a general question regarding the linker script generated by STM32CubeIDE.Most of time the STACK and HEAP is placed together into the "same" internal SRAM (see section .user_heap_stack example for demonstration purpose). Note: Yes, there ...
Floki.1 by Associate II
  • 4550 Views
Ethernet communication not working in ST32Cube IDE 1.9.0
Hi,I have a custom board with STM32f427VG and KSZ8041NL PHY. My ethernet communication is working well in STMCube IDE 1.8.0. But when I try to configure ethernet in ver:1.9.0 I don't see a input box for PHY address. It says it some ethernet settings ...
SSala.3 by Associate III
  • 1398 Views
  • 1 replies
Resolved! Login to st.com website fails
I want to download STM32CubeIDE debian version to my laptop. When I click Get Software-->Accept-->Login/Register I get the error " SORRY, PAGE NOT FOUND " . You can see the details at the picture I attached
Post-generation hook in STM32CubeIDE
In our workflow around the code generation and building firmware using STM32CubeIDE, we have certain manual steps after code generation.Is there a place to hook in a script to be run after code generation completes? Similar to the "Build Steps" which...
JKut by Associate II
  • 2950 Views
  • 6 replies
