STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1558 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 591 Views
  • 0 replies
Resolved! Why do i get Device not found in STM32CubeMonitor
I am using a custom board equipped with an STM32G473 controller and use ST LINK V2 .Recently, I decided to explore the usage of CubeMonitor for the first time. While the YouTube videos I watched provided clear instructions, none of them mentioned any...
_legacyfs_online_stmicro_images_0693W00000bjs45QAA.png _legacyfs_online_stmicro_images_0693W00000bjs4PQAQ.png _legacyfs_online_stmicro_images_0693W00000bjs5IQAQ.png
sde c.1 by Senior II
  • 3336 Views
Resolved! How to access mutexes and semaphores generated by STM32CubeIDE FreeRTOS integration from another file?
I'm using a mutex to share the I2C bus between an OLED display and an EEPROM. I'm using the IDE to generate the FreeRTOS configuration and tasks initialization (freertos.c file). I have an external file where all the LCD writing occurs. How could I a...
Dolence by Associate III
  • 2926 Views
  • 1 replies
bug: STM32CubeIDE build failed after Project->Clean
2019-05-28Windows 10 64bit CubeIDE Version: 1.0.0Build: 2872_20190423-2022 (UTC)Project had been compiling+linking fine.Restarting the IDE does not help.arm-none-eabi-gcc -o "cubeide-rtos-spi1-uart1-a.elf" @"objects.list"  -mcpu=cortex-m4 -T"C:\Users...
Sking.21 by Associate III
  • 6711 Views
  • 7 replies
  • 2 kudos
Resolved! How to replace GUI action with command line?
I'm writing initialisation script.Project repo is cloned into my empty workspace.At the moment the user must initialy run STM32CubeIDE select empty workspaceCall File > Open Projects from File System ... > select Folder and confirmThis action is what...
DrDro by Associate III
  • 1488 Views
  • 1 replies
  • 1 kudos
Strange behavior of IDE (modifies my code)
Hello!I have a weird problem with IDE.I have defined a structure which aims at initializing a menu item.This structure contains a few items including an opcode to be sent to an FPGA.The name of the structure is panel_config_item.Then I have declared ...
PG.1 by Associate III
  • 4577 Views
  • 7 replies
How to move (copy/paste) a STM32CubeIDE project to another PC?
with different paths and versions of STM32CubeIDE and Embedded Firmware Packages?In other words, if we want to share a STM32CubeIDE among our colleagues, what is the way to migrate/duplicate/re-create a STM32CubeIDE project? We are new to ST's MCU an...
WQ by Associate III
  • 11149 Views
  • 8 replies
