STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1440 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 565 Views
  • 0 replies
Cube_IDE color
Hello, Is it possible to change the color of the tabs on Cube IDE? See attachment.Best regards.Sebastien.
PSEBA.1 by Associate II
  • 836 Views
  • 1 replies
Resolved! STM Cube IDE installation problem in RHEL
I am facing an issue while installing the cube ide in  my rhel 9.2 version,the exact problem was when i try to run the executable file and going through the instructions ,after agreeing the licenses and the folder which contains .rpm files is deletin...
undefined reference to `SEGGER_RTT_ASM_WriteSkipNoLock'
Hi,i am trying to port FreeRTOS to my STM32L152RCT6.i did it successfully.but when i am trying use segger debug tool.i am facing issue like this  18:09:25 **** Incremental Build of configuration Debug for project freertosporting **** make -j4 all ar...
chaithu by Associate II
  • 2857 Views
  • 4 replies
STM32CUBEIDE inc src hidden
I wanted to check out the HID Master USB example from ST for my STM32H7B3I-DKIt would not compile, forcing me to upgrade my CubeIDENow it compiles, but inc & src folders do not appear in Project explorer.  They are there on the hard diskThe inc and s...
BBrow.2 by Associate III
  • 1233 Views
Resolved! How can I add files to a STM32CubeIDE project as links?
If anyone is familiar with Code Composer IDE, CCS allows me to add files to a project as links. If this is not possible, perhaps you might have suggestions of how to share common code files between projects without replicating the common code.
phgphd by Associate II
  • 6084 Views
  • 5 replies
Issue in creating new project using STM32IDE
Hi team,I am using STM32IDE version 1.7.0. when I trying to create new project by selecting STM32F373VC as the controller. I am getting an error message saying, "Error downloading the following files: stm32cube_fw_f3_v1115.zip (Timeout during downloa...
KKB by Associate
  • 1741 Views
  • 1 replies
  • 1 kudos
