STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 136 Views
  • 0 replies
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4032 Views
  • 0 replies
  • 3 kudos
OTA FW Update not working, compatibility issues?
Hi, I have the following problem:I am developing Firmware for a device that has a STM32WB55VGY6 on it. Right now I'm in the midst of trying to get a OTA FW Update to work, but I'm completely stuck. Whenever I try to upload a .bin file via the BLE Sen...
MaZ by Associate
  • 1344 Views
  • 1 replies
How to use the stm32wbcc series
I want to know how to design a PCB board about stm32wb55cc serial ic ,and should it need a antenna​?If it need, what is the most suitable antenna to the ic?
TShen.1 by Associate
  • 826 Views
  • 0 replies
STM32WL55JC1 sampling rate is different
Hello everyone, I am trying to do tone calculator. I am using DSP , ADC ,DMA and timer for sampling rate. I am using tone genarator and for example if tone is 500 hz and my fftoutbuffer[16] is going high value (noramlly 130 but when tone generate is ...
_legacyfs_online_stmicro_images_0693W00000bkOWBQA2.png _legacyfs_online_stmicro_images_0693W00000bkOW6QAM.png _legacyfs_online_stmicro_images_0693W00000bkOVhQAM.png
AHakk.1 by Associate III
  • 760 Views
  • 0 replies
Regarding RTC update in I-CUBE-LRWAN project
Greetings,I am working on the LoRaWAN Project and facing issues in updating RTC from a server/UART in LoRaWAN library.My code is getting stuck while updating RTC, I am recieving time and from UART through user input.RTC_TimeTypeDef set_time;RTC_DateT...
DSehg.1 by Associate
  • 748 Views
  • 0 replies
