STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 219 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4065 Views
  • 0 replies
  • 3 kudos
How i can resend same uplink frame on gateway failure or off ?
Hi,im using a loRawan module based on STM32WLE5 chip.i would like to know how i can save an event to reTx it on the next uplink when i have my gateway off or during a blackout . im trying not to lose info .my Tx duty cycle is every 90 minutes or on b...
rib.1 by Associate II
  • 1027 Views
  • 0 replies
STM32WB55 Nucleo --- working with debugger and not without
Hello all....Looking for some pointers. I have an application I created in CubeMX/IDE on a WB55 nucleo board. I am using nRF Connect app on my phone as the Client. When I run the nucleo server application with the debugger connected all seems to work...
SWenn.1 by Senior III
  • 1667 Views
OTA FW Update not working, compatibility issues?
Hi, I have the following problem:I am developing Firmware for a device that has a STM32WB55VGY6 on it. Right now I'm in the midst of trying to get a OTA FW Update to work, but I'm completely stuck. Whenever I try to upload a .bin file via the BLE Sen...
MaZ by Associate
  • 1375 Views
  • 1 replies
