STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 221 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4067 Views
  • 0 replies
  • 3 kudos
Resolved! Example Project RTC_LSI GetLSIFrequency undefined value
Good morning,I am trying to follow the RTC_LSI calibration example project for the P-NUCLEO-WB55.https://github.com/STMicroelectronics/STM32CubeWB/blob/master/Projects/P-NUCLEO-WB55.Nucleo/Examples/RTC/RTC_LSI/Src/main.cThe GetLSIFrequency function h...
POliv by Associate III
  • 1536 Views
  • 1 kudos
Resolved! STM32WB55 internal antenna
Hello, I have a question about the internal antenna of the STM32WB55CGU6.First of all, does it have the internal antenna? And if so, what is the range of it? Thanks
Resolved! Zigbee - Custom cluster attribute reporting only on connect
Hey,I working on a project with the following goal: setup one central coordinator and let multiple sleepy end devices send sensor data periodically. For development I am trying to alter the code of the Zigbee_TempMeas_Client_Router/Zigbee_TempMeas_Se...
user5 by Associate II
  • 4490 Views
  • 7 replies
Stand-By mode when RFWakeupCLK is LSE
Hi there,if i try to set my stm32wb55cg into standby, it seems to only work if the RFWakeupCLK is HSE-DIV1024void PeriphCommonClock_Config(void) { RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0}; PeriphClkInitStruct.PeriphClockSelection = RCC_...
Exeu by Associate III
  • 2367 Views
  • 3 replies
Resolved! STM32WB55C Based BLE module design verification
Hi Team,Am designing a BLE module using STM32WB55CEU6 for an IoT audio streaming project. Can somebody please help me in verifying the RF portion of schematics and layout. We are using an IPEX connector on board for BLE antenna and the signal is conn...
Resolved! Custom Bluetooth Service
Hello, I need your kindly support for this application.I would like to do a code for the STM32WB5MM-DK where the Bluetooth have a service with the following characteristics:ServiceCharacteristic 1: Read and Notify a random number from 0 to 100 (later...
[ STM32WB5MMG ] : HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE
Hi,In my product, I use the STM32WB5MMG module as Bluetooth link with the rest of the product.The STM32WB5MMG module is configure as Client.But during the discovery procedure, I always go to :- SVCCTL_App_Notification ->  case HCI_VENDOR_SPECIFIC_DEB...
arault by Associate II
  • 1579 Views
  • 1 replies
