STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
Resolved! WB05N interface/update
I am in a similar situation to @Richard Lowe back here:https://community.st.com/t5/stm32-mcus-wireless/looking-for-uart-guidance-for-the-stm32wb05kn-network-co/m-p/721231The getting started guide from the last post there references a "X-CUBE-WB05N us...
OliM by Senior II
  • 1400 Views
Resolved! Mistake in wiki page
Hi, I was learning how to work with STM32WB55RG, using the following wiki page: https://wiki.st.com/stm32mcu/wiki/Connectivity:STM32WB_BLE_STM32CubeMX   The tutorial here is top notch, great explanation and examples, easy to follow. Only error is tha...
Resolved! How to use LSI instead of LSE with STM32WBA55
Hi,I use the example “BLE_p2pServer_ota” with NUCLEO-WBA55 as a template for a project.For space reasons and to save costs, I would like to use the internal oscillator LSI1 (32,000kHz) instead of the external 32,768 chrystal LSE. After switching to L...
ledi001 by Senior
  • 3609 Views
  • 5 replies
  • 3 kudos
Resolved! STM32WL33 Debug prove ST-LINK(ST-LINK GDB server) not working
Hi All,I have just started a project with STM32WL33CC1 MCU. To get started I am trying to run and debug the example MRSUBG_Chat project.The project builds fine but refuses to enter debugging.I can program the WL33 using STM32CubeProgrammer and STM32_...
ola by Associate III
  • 4255 Views
  • 8 replies
  • 2 kudos
Resolved! STM32WB55: Rejoining a Zigbee Home Assistant network
Hello, I'm trying to create a smart device to connect to my Home Assistant network using Zigbee. So far, I've been able to connect to the network and control a light (turning it on and off), which works perfectly. The issue I'm now facing is rejoinin...
