2023-02-15 12:50 PM
I would like for my services and characteristics to have a user readable string name.
(when someone discovers them)
How do I set that name in the descriptor of the attribute?
Is there a convention on how the descriptor need to be set so devices will show that name?
In your data sheet, it seems like only characteristics' descriptors can be set, is it the same command for a service?
If you have an example that sets some string names to attributes would be great to have as well.
2023-11-05 9:00 AM
I would like to know if you ever found a solution to this as I am struggling with the same issue.....user readable string names are not broadcast/transmitted, making it confusing to interpret.
2024-07-14 7:12 AM
Same question here
