STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 228 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4070 Views
  • 0 replies
  • 3 kudos
Resolved! I2C HAL Size Management error - STM32WL + Si7021
What does this error mean for the I2C interface? I have it on the connection between the LORA E5 Mini and the SI7021 sensor.The debugger stops here:Exactly at his method call:  /* Wait until TXIS flag is set */ if (I2C_WaitOnTXISFlagUntilTimeout(hi...
markpow by Senior
  • 4920 Views
  • 10 replies
  • 4 kudos
BLE data every 5 ms
Hello,I designed my custom board using STM32WB series to be connected to sensor and send data to CLIENT which is my laptop.  I am able to use Write and Read Characteristics for a single character.Now I intend to use READ characteristic to send data e...
Nico3 by Senior
  • 2383 Views
  • 7 replies
Resolved! STM32WBA50KG BLE 5.4 Output power
Hello,I need clarification about the STM32WBA50KG Tx Output power for BLE 5.4.It seems that there's an inconsistency in the value of the Tx Power.This page STM32WBA50 overview  mentions +10dBm.But the datasheet STM32WBA50KG datasheet  mentions +4 dBm...
SamC by Associate II
  • 1665 Views
  • 4 replies
  • 1 kudos
Resolved! STM32WL33 6LoWPAN
Hi, STM32WL33 is part of 6LoWPAN products, but in Firmware package there are no examples for 6LoWPAN. Can someone explain how to incorporate 6LoWPAN in STM32WL33 series ?
faruk by Associate
  • 11522 Views
  • 4 replies
  • 1 kudos
End Device HardFault after switching to ClassC
Hello,I'm working with Actility as server, on a NUCLEO-WL55JC as the End-Device. I have the STM code from the STM32obeWL repository, version 1.3.0. When running a FUOTA campaign from the server the last update sent from the end device in the serial p...
oronshifman_1-1734872265199.png oronshifman_2-1734872930882.png oronshifman_3-1734873163308.png oronshifman_4-1734874171808.png
