STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
STM32F746BG Offload .rodata onto QSPI
Hello,I have moved an .rodata portion of a file onto the QPSI. This happens to be a TouchGFX file that has a lot of rodata. It is FrontendApplicationBase.oWhen I change code else where in my project (unrelated to TGFX or the FrontendApplicationBase),...
Cannot debug STM32F7508-DK
Hello,I had success in creating and debugging a blinky project when created from cube IDE, but not using touchgfx generated project for this boardI am not able to start a debugging session for project created by touchgfx. Things I have tried:1.Explic...
EJ.1 by Associate II
  • 4633 Views
  • 8 replies
TouchGFX DSI video mode issues
Hi ST community, as others in the forum, I'm trying to work with TouchGFX on a display in video mode.I started form the LCD_DSI_VideoMode_SingleBuffer with the purpose to have the Video Mode working on another display (based on st7701s controller). T...
LBaga.1 by Associate II
  • 7990 Views
  • 19 replies
Problem with STM32L0538-DISCO [e-PAPER]
Hi,I have a problem with running the embedded e-paper display in STM32L0538-DISCO. I can't find any example working on STM32CubeIDE. I have tried to write the code myself but it is quite complicated.So I would like to ask if someone has any simple ex...
VEGA1 by Associate
  • 2514 Views
TouchGFX Wish List
You guys from ST have made great strides in improving TouchGFX (keep up the great work!) so I don't want this to come across as a negative comment. But I think there are things that could be improved. I think others may have suggestions as well.I tho...
scottSD by Lead
  • 7219 Views
  • 23 replies
  • 1 kudos
Font Dither Adjustment
I am having a problem with on-screen fonts. The dither/font-smoothing applied to the fonts eats into thin segments of the characters too much. This causes them to be too dim on screen for my application.I've managed to show that the problem clears ...
Dfarr.1 by Senior
  • 1646 Views
  • 1 replies
