STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Help to fix a TouchGFX custom board project
MCU : STM32H743ZISTM32CubeIDE 1.10.1TouchGFX 4.18.1I created a stm32h743 project with cubeMX and created a simple red screen as in this video https://www.youtube.com/watch?v=SRQD8JMeg_k&t=3034sI added the fix in this topic https://community.st.com/s/...
TouchGFX cube_programmer.mk project File template
TouchGFX projects has a cube_programmer.mk in each project folder.I have installed my CubeProgrammer in a different location to the default location in the cube_programmer.mk. I was wondering if the cube_programmer.mk is created on each project creat...
Where is Code editor in TouchGFX also where is output window to know errors generated? Run failed for me, where to check for errors?
I am new to TouchGFX. I am working on STM32 controller based project. In that TFT LCD screen is one of the peripherals. I want to create screens using TouchGFX so that i can set value on screen and run timer according to the value entered on screen, ...
ABeck.1 by Associate II
  • 9354 Views
  • 25 replies
Getting Frame by frame video output.
Hi Community,I have got the video output , using video widget in Touch GFX (v4.19.1). But video is playing frame by frame as attached in video. Anyone is having idea about the solution for the same?IDE : STM32CubeIDE (v1.10.0).Designer :Touch GFX Des...
Vins by Senior
  • 2089 Views
  • 3 replies
Why is the text area not getting resized?
I am able to display the P_soc properly but when I tries to print (P_temp_h)*0.1 if it is 4 digit( i.e 2 digit before decimal and 1 digit after decimal and decimal point) then I could display the data properly. But If it is 5 digit then the function ...
KMod3 by Associate II
  • 1604 Views
