STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Resolved! Hour and minutes
Good morning , sorry if i'm not posting in the right place but i'm still learning. I have a problem with an example i saw in the tutorial where you bild an iterface to adjust the hour and minutes . In the tutorial where i built the interface it says ...
StefanoL by Associate III
  • 6330 Views
  • 16 replies
  • 6 kudos
Custom trigger
Hello, Is it possible to create a custom trigger for box shape?I would like to move the box using interaction, but I would like to trig this interaction from source code, is it possible? Thanks,Best regards,Laurent
lclor by Associate III
  • 2211 Views
  • 3 replies
  • 1 kudos
TouchGFX Run Simulator Fail
Hi,I tried to install TouchGFX 4.23.0 and 4.23.1 several times. OS is Win 11 pro eng/us region and eng language settings.When executed the run command on windows simulator fail message appears as in attachment.Also fails when creating any discovery b...
ali_ by Associate II
  • 11883 Views
  • 9 replies
  • 5 kudos
Upgrading TouchGFX engine and external buttons
This is an outstanding issue that's been there for a while but since it just got me again, I'm finally taking the time to post about it.  When using external buttons and the button controller, the implementation instructions have you edit the ToughGF...
Jazman by Associate III
  • 2234 Views
  • 3 replies
