STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
How to add % to a text widget
Hi there TouchGFX team.  I need to print a percentage value on a text widget. The progress bar doesn't fit me, I just need the value to be displayed. This is done in the widget configuration or is done in code by the dev concatenating the "value" + "...
JPabl.1 by Senior
  • 1156 Views
  • 1 replies
Define custom generic base view
Hello,I am building an application that contains many screens.All the screens share the same containers and modal windows.I am found myself obliged to duplicated treatment for different containers and models on each screen.My question is:Is there a w...
AMS22 by Associate II
  • 1620 Views
  • 3 replies
ILI9488 and STM32F432CHU6
Dear all!i need help, I try to fill Screen in Red, but can't. I download library from GitHub. I don't know how to fix it. i attach original library, i disable 1 line in C file. Pin PB7 control 1 led and it blink as my expect, can you help share me ho...
Post Generate (Target) Command
Hi,I'm struggling to do something that should apparently be relatively simple. I want to import a different touchgfx.props file to the .vcxproject depending on a variable. Now, you might wonder why I want to do that, so let me explain quickly the rea...
GMeur by Senior II
  • 2340 Views
  • 4 replies
  • 1 kudos
