STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Resolved! Changing scene in Model.cpp fails
I have a hardware trigger that needs to change a scene (think a Home button but I cannot use a hardware key event).I am trying to change the scene for days but I cannot find a working solution.The best looking solution was this: https://community.st....
starcin by Associate II
  • 4553 Views
  • 12 replies
Resolved! STM32U575 and TouchGFX ends in FaultHandler
Hello Everyone, I have a STM32U575 CPU, with a ILI9341 LCD Display, this works fine with a STM32F4, but i am upgraded my PCB to a STM32U575 and got Problems with the SPI...my main.c code: int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE EN...
Sany by Associate III
  • 3003 Views
  • 7 replies
  • 3 kudos
Resolved! How to use SVG in touchGFX
Hi there,In my touchGFX project, I import an SVG file.I can compile and simulate the UI page using TouchGFX Designer, which works as expected.However, after I finished the design in TouchGFX Designer and tried to compiler the project by MDK-ARM, the ...
Junde by Senior III
  • 2236 Views
  • 4 replies
  • 4 kudos
How to add % to a text widget
Hi there TouchGFX team.  I need to print a percentage value on a text widget. The progress bar doesn't fit me, I just need the value to be displayed. This is done in the widget configuration or is done in code by the dev concatenating the "value" + "...
JPabl.1 by Senior
  • 1131 Views
  • 1 replies
