STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1532 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 584 Views
  • 0 replies
Resolved! My code stops working after a while
I'm trying to use DHT22(temperature and humidity sensor). I'm using STM32F030F4 Here is it's datasheet DHT22 DatasheetIn first few seconds. I can get values. But after a while it stucks in here:So i try to implement a timeout to prevent this. I start...
Resolved! What does User Constants in the Device Configuration Tool do?
Hello,I would like to use a global variable in a while loop in my main file. That variable will be set to zero in a interrupt. Unfortunatly the interrupts are created by the device configuration tool in a seperate file. In the device configuration to...
Eden.757 by Associate
  • 2714 Views
  • 1 kudos
stm32cubeIDE bug include folder
Hi,There is no stm32cubeIDE section so I post it here.I found another bug that isn't mentioned on the known issues and I found no bug tracker to post this issueWhen you re-generate code using the integrated cubemx, all included folders (in properties...
bet by Associate II
  • 693 Views
  • 0 replies
