Problem in using stm32cube ide
ADube.283
I am getting an error saying-
"Create minimal project failure- cannot read template source"
Angelos1
did you try to open the IDE with administration rights?
also there is a newer version of the IDE, 1.1.0 so you can also try to update it.
Thanks for your reply,
yes i have tried opening it with admin right and i have the same version installed, that is - 1.1.0
 Still getting the same error message
