STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1544 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 586 Views
  • 0 replies
CubeIDE cannot import Atollic project (details)
So I'm now trying to import Atollic project into CubeIDE.Started from this: Then entered path of the source projectThe project is in subdirectory PROJ_ATOLLIC so I've unchecked the upper item.(Does it really think that the project is SW4STM?? Hmmm) C...
0693W000007Yz6GQAS.png 0693W000007Yz6LQAS.png 0693W000007Yz6QQAS.png 0693W000007Yz6VQAS.png
Pavel A. by Super User
  • 2141 Views
  • 4 replies
CubeIDE permanently deletes all projects
CubeIDE 1.5.1CubeMX 6.1.1Just got all the projects + files in a folder permanently deleted by CubeIDE when creating a new project.Permanently meaning that the files didn't go to the bin.What happened is that, using CubeIDE, I tried to create a new pr...
Resolved! Anyone know how to resolve a "fail to get required stm32cube firmware package" error when importing a new project?
I tried importing a project using STM32CubeIDE V1.4 and got the following error: I tried doing package updates and everything I could think of but I wasn't able to figure out how to resolve this (tried googling/forum searching it but no luck). Anywa...
JBee.1 by Associate II
  • 8828 Views
  • 10 replies
  • 2 kudos
Thumbs2 instruction set only ?
When you go the Tool Settings tab in the Project Properties you are only able to select Thumb2 for the instruction set.Is it intended or is there a "hidden" way to switch to the ARM instruction set ?
JLABO.1 by Associate II
  • 3082 Views
  • 3 replies
Resolved! Colors in CubeIDe
How to change background color of the elements that I have selected but later removed that selection in dark theme? If I select CDC_Receive_FS, for example, and it is green in dark theme, after I continue to do anything the background of all instance...
EL314 by Associate III
  • 5631 Views
  • 3 replies
