STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1436 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
Suddenly CubeIDE doesn't run and debug mode.
I deleted CubeIDE and reinstalled the latest version 1.10.1, but it still doesn't work. The test environment was tested with NUCLEO-G071RB with the most basic code. Even if you delete and reset the RUN and DEBUG configration by referring here and the...
YShin.5 by Associate II
  • 4427 Views
  • 6 replies
Resolved! How can i upload/download my code to MCU/SD Card?
Im working on stm32f767 project. I designed my board. I want to upload&download my code. First step i need to take backup (download) my code after that creating a file (xml..?) to SD card. Also i want to upload code which in SD card to MCU. How can i...
KAnahar by Associate III
  • 5108 Views
  • 7 replies
Resolved! Problem while enabling TIM2 in STM32G041J6M6
Hello,I am using the TIM2 with the STM32G041J6M6 and I am finding problems while enabling TIM2 using registersWith some code I have initiated the timer as reported below (TIM2 clock is enabled) While debugging I can edit some timer registers (ARR,PSC...
Tommino by Senior
  • 2974 Views
  • 7 replies
Count external pulses
I want to count external pulses for one second.On STM32F030 / HAL-Lib I did not findatomic read/reset countercapture by a second timer did not work, thoug I studied well and tested a lot how to config it by STM32CubeIDEIs there any example for a high...
peterka by Associate III
  • 10572 Views
  • 15 replies
  • 1 kudos
