STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1450 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 568 Views
  • 0 replies
SWV Timeline error -500000000
Hi,when I am plotting data with SWV timeline, the timeline randomly plots -500000000 or lower values, while plotted variable does not drop that low. Don't you know, where could be the problem? I did the easiest program, but the SWV still has this err...
Resolved! Linux Installation Error - STM32 Cube IDE
I have a VM running with Ubuntu 22.04 -- a brand new, clean installation.In case it matters...The host machine is a Mac M3I actually had this running some time ago, but have since deleted the VMI am working with an offshore team doing some dev work f...
sparrow by Associate II
  • 4573 Views
  • 5 replies
  • 1 kudos
CubeIDE Debug Application with BootLoader
I am porting over an application from SystemWorkbench to CubeIDE. This application has a bootloader and application. The application is loaded at 0x08008000. With SystemWorkbench I added a linker flag of -nmagic, but in CubeIDE that throws an error. ...
Stephen28 by Associate III
  • 6047 Views
  • 6 replies
  • 2 kudos
(DEV_TARGET_RESET_ERR)
 Hello,I’m trying to program my STM32 microcontroller STM32F301C8T6TR using ST-LINK, but I keep getting the "DEV_TARGET_RESET_ERR" error. Here’s what I’ve tried so far:Reset Pin (NRST): Connected directly to the RST pin of the ST-LINK.BOOT0 Pin: Conn...
Build GNU Tools for STM32 12.3.rel1
I am trying to build the toolchain and I'm looking for some help getting over this hurdle.When I run build-prerequisites.sh on Ubuntu, it stops when it tries to run "helper.py" with the error "You need to install python-magic."  Helper.py is running ...
Unable to compile BLE projects for WBA MCUs.
I've been trying several days to just get any project up and going for the STM32WBA52GU. As soon as I add the WPAN middleware, the HAL definitions go haywire with errors when I compile it. I've tried following tutorial in the wiki with documentation,...
JLReyno by Associate II
  • 1269 Views
