STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 132 Views
  • 0 replies
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4028 Views
  • 0 replies
  • 3 kudos
Resolved! X-NUCLEO-GFX01M2 SPI frequency
Hello,I am currently using a X-NUCLEO-GFX01M2 screen to display logs from a NUCLEO-STM32WL55JC board. Unfortunately, it is quite slow to display the logs, so I wanted to improve the SPI frequency. I tested it by lowering the SPI BaudRatePrescaler fro...
Resolved! NUCLEO-WL33CC1 Range
Hello ST community,Just thought of buying NUCLEO-WL33CC1 for development of flight telemetry. But I have few doubts before buying.1. What is the radio coverage distance with the default antenna that comes along with the kit? Assuming the test area is...
Resolved! STOP0 mode with STM32WL55JCx
Hello everyone, I'm currently working on several projects on STM32Cube IDE with each of them implementing the different low-power modes available on the Nucleo-WL55JC1 board (Sleep, LPR, LPS, STOP0-1-2, Standby and Shutdown).For each of them, I follo...
MadANDT by Associate II
  • 2359 Views
  • 3 replies
STM32WB1MMC module on 4-layer PCB
My current project is a small (15 x 30 mm) PCB, with 4 layers. I use the STM32WB1MMC module for BT connectivity.  Are there things to consider when designing this 4-layer PCB in order to maximize BT range?Thanks!
_Ben by Associate
  • 709 Views
  • 2 kudos
