STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 222 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4067 Views
  • 0 replies
  • 3 kudos
RTC in Standby on STM32WL
Dear communityI'm working on a project using STM32WLE5J microcontroller. I would like to collect time from some external source and then keep it on the device. My problem is that the device loses its internal time after waking up from standby (e.g in...
KS.6 by Associate
  • 1891 Views
  • 1 kudos
How can i figure out the Pin voltage of Board STM32WB55RGVx
Hi,How can i find the Pin voltage of different Pin of Board P-NUCLEO-WB55-Nucleo(stm32WB55RGVx), Especially the Pins used for UART communication? (Tx and Rx Pin)I didn' find a clear information in the Datasheet of this board:https://www.st.com/resour...
mmed by Associate III
  • 2795 Views
  • 5 replies
STM32WB55 OTA_BLE ST BLE Sensor
Helle Evryone , I juste wante to modifiy my file no-ota to file ota, i following the video in youtube https://www.youtube.com/watch?v=mRzZOa3jmuM but the problem whene I want to change start adress my application don't work
SOMAR.1 by Associate
  • 1576 Views
STM32WB Get wireless stack version at runtime
Hello,I'm using STM32Wb CubeMX HAL FW 1.10.1 and a PNUCLEO-WB55I'd like to get the wireless coprocessor stack version at runtime. I didn't find a HAL API to do this, so I went about it manually using AN5185 as a guide. According to AN5185, the devi...
svcguy by Associate III
  • 1143 Views
  • 0 replies
  • 1 kudos
Understanding STM32 Sequencer ( Simple scheduler )
I am going through the Hands-on2 and Hands-on3 in STM32WB55 MOOC. In the both examples sequencer or simple scheduler is used for the BLE. Inside the while loop I found only the Seq_run() function. I want to learn how the sequencer works. Can anyone ...
SChan.8 by Associate II
  • 8531 Views
  • 6 replies
  • 4 kudos
Resolved! Unable to start firmware upgrade service STM32WB35CCU6A
Hello,I have a custom PCB using a STM32WB35CCU6A that I'm trying to get Bluetooth up and running. I'm using the latest firmware available at this time: "STM32Cube_FW_WB_V1.10.1".I've been unable to get CPU2 to initialize from my STM32CubeIDE project....
MAlbr.1 by Associate II
  • 8843 Views
  • 7 replies
Resolved! GAP Observer Role
I am building a device that has to register data that is send in BLE beacons. I want to filter this data out of received Advertisement messages. Are there any implementations of this capability that I can learn from? I started from the P2P Client ex...
JVan.1529 by Associate II
  • 2111 Views
