STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
Resolved! STM32CubeMonitor-RF 802.15.4 RF test mode
Hello.I have a STM32 Nucleo board and a USB dongle. What Stack and FW should be programmed to use STM32CubeMonitor-RF 802.15.4 RF test mode described in chapter 5 of the UM2288?Thanks.
dimax by Senior
  • 2780 Views
  • 4 replies
Information about mesh network and configured nodes
Hello,I have created mesh by embedded provisioner. Mesh contains, let's say, 5 more nodes. I know where are saved node addresses, number of elements and device keys for all nodes (embedded provisioner has them saved in NVM memory). Is there any func...
fiiita by Associate
  • 750 Views
  • 0 replies
Low throughput in p2p server example
Hi there!I added 3 characteristics to the p2p server example, with lengths of 2, 2 and 64 bytes. Event processing occurs directly in the p2p_stm_app_notification (p2p_server_app.c) function. The Client performs 16 iterations a La:{ char1.write(2...
Resolved! STM32WLE5 Segger J-Link debugger not supported
Hi,I'm working with the new STM32WLE5 MCU. I switched to our custom board recently, and because of that I'm using a Segger debugger. Prior we used a Nucleo board with the STLink debugger and that worked fine. Now I adjusted my debug settings for the ...
