STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
Resolved! STM32WB55 Nucleo Pack - Getting Started Series - Phone App can't/is unable to find the Board/BLE-Application
Hello, I wanted to ask if anyone actually is doing (or has already done successfully) the STM32WB Getting Started Series on youtube (STM32WB Getting Started Series - YouTube) and the according Nucleo Pack (P-NUCLEO-WB55 - Bluetooth 5 and 802.15.4 Nuc...
MJoch.3 by Associate II
  • 5337 Views
  • 9 replies
  • 1 kudos
STM32WB55CEU RF Test for certification
Hello!!I developed a BLE product with STM32WB55CEU. I am preparing certification.To be certified, the STM32WB55CEU must be set up for RF testing.I set it up with Transparentmode FW for P-nuleoboard. But it didn't work.Different chipset seems to be th...
SOh.3 by Associate
  • 1187 Views
  • 1 replies
STM32_WPAN middleware not showing up
I am following this tutorial for setting up my STM32WB55 dev kit. When I generate the code and try to compile I get the following error:../STM32_WPAN/App/custom_stm.c:22:10: fatal error: common_blesvc.h: No such file or directory../STM32_WPAN/App/cus...
ADing.1 by Associate II
  • 2685 Views
  • 1 replies
How does the STM32WB SRAM2 wireless stack boundary work?
Is it correct that the WirelessFwInfo_t.MemorySizeSram2A/B members describe the wireless stack occupied areas of SRAM2 in terms of 1k units (growing downwards)?I am noticing there is memory being written to at 0x20031000 onwards, but that doesn't lin...
_legacyfs_online_stmicro_images_0693W00000bhmmMQAQ.png _legacyfs_online_stmicro_images_0693W00000bhmmWQAQ.png
MSatt.4 by Associate III
  • 1443 Views
How to Restore frame count after reset Lorawan context?
I have developed a device that joins lorawan in OTAA mode. I am testing the device and i am having some problems with conectivity.Device joined succesfully to Lorawan Network Server, i saved the NVM Lorawan context and i reset the device, after reset...
RPaja.1 by Associate II
  • 2457 Views
  • 1 replies
using only one core in STM32WL product.
recently I received STM32WL development kit. it based on STM32WL55.This is my First use case of Dual Core STM32 and I don't know how it working. My project didn't need Dual core. so I try using only one core but it seems not working my expectation. i...
help by Associate
  • 1342 Views
  • 1 replies
Resolved! STM32WB + QSPI for nand flash
My development environment is stm32cubeMX and IAR.​​First of all, the configuration I programmed is like this.1. Init (write Status Register WP-E set 1)2. Block Erase (to the address where i will store the data)3. Write data to buffer4. Program Execu...
KWOOJ by Associate III
  • 12358 Views
  • 8 replies
