STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 257 Views
  • 1 replies
  • 2 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4090 Views
  • 0 replies
  • 3 kudos
Resolved! Pointer to simpliest example for STM32CubeWL sequencer
Appreciate pointer to simpliest example for STM32CubeWL sequencer.Specially "Task registration and execution" and "Wait for an event and set event" to do the below sequence.  I have AN5406 and reading.....read temperature sensor,  transmit on STM32WL...
David_ by Senior
  • 1559 Views
  • 3 replies
  • 1 kudos
Resolved! Flashing stm32wb5x_BLE_Stack_full_fw.bin to wrong address
I use stm32wb5x_BLE_Stack_full_fw.bin v1.13.2 on STM32WB5MMG.The installation address is 0x080CF000.What happens if I write the stack to the wrong address (0x080C7000, the install address for v 1.13.0).In my board, it looks work fine. Is there any co...
TK by Associate
  • 1139 Views
  • 1 replies
Resolved! Receiving Data from BLE (STM32WB Series BLE Issue)
Hello, I'm STM F/W Beginner .Recently, I was tasked with a project to implement BLE with the Stm32wb MCU.As a result of referring to Example such as Heartrates or P2PServer Projects, I could successfully send Data to a mobile phone by Nucleo Board.Ho...
remoter by Associate III
  • 3393 Views
  • 4 replies
  • 4 kudos
attempts to connect to the gateway
Good morning,I am using an STM32 WL55JC1 starting from the end node example.I am unable to figure out in the code how to set how long or how many tries it makes before it stops trying to connect to the gateawy.Could you please point me to this inform...
IngSerio by Associate III
  • 2481 Views
  • 4 replies
related to ble
i set fido related services and characteristics using cube mx for stm32wb55 development board why i am not getting any value in my coustum event handler.
amit_ble by Associate
  • 1797 Views
  • 3 replies
  • 2 kudos
Looking to operate WL55jc1 and L072Z LRWAN1 in Class C.
@ST Community @STTwo-32 @Tinnagit @Tesla DeLorean 1) I have done few changes from "#define LORAWAN_DEFAULT_CLASS CLASS_A" to "#define LORAWAN_DEFAULT_CLASS CLASS_C" in the "lora_app.h" file and I also changed "#define DISABLE_LORAWAN_RX_WINDOW 0" to ...
Yuvi by Senior
  • 749 Views
  • 0 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
