STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
Where is the "Debug Authentication" ?
I used a MB2032-WB09-B02 on MB1801D for several times, flash in CubeIDE was always OK, though debug prompted error read data every time, then the next day when I used it again, it didn't work, I couldn't flash image into neither in IDE nor Prog, the ...
MQi.1 by Senior II
  • 3424 Views
  • 8 replies
Resolved! STM32 WPAN Remove BLE Service
Hello, I have an existing STM32_WPAN configuration with 3 BLE services and I want to completely remove Service 2. Is there any way to do that?  I've already reduced the number of services to 2, but it ends up removing Service 3 which I want to keep. ...
dsmail1 by Associate II
  • 1060 Views
  • 1 replies
Scanning and Detecting STM32WB09KE - Custom PCB
Using STM32CubeIDE 1.17.0, STM32CubeMX 6.13.0, MCU is STM32WB09KEV6TR.ioc file attachedHello,I am trying to write code for a PCB with an STM32WB09KEV6TR. I am very new to STM development. Before going any further in our project, I am simply trying to...
Resolved! BLE disconnect --> HCI_Reset unexpected behaviour
I am working on a low power mode in a freeRTOS ble application. On a user request the device is to go into low power mode Stop2. In order to achieve the lowest power consumption ~2µA (stm32wb55) the ble activity has to be deactivated and the cpu1 & c...
BLE de-initiatization and reinitialization.
I am working with STM32WB55RG microcontroller. The application that I am working on needs to enter BLE mode when requested by user. I am able to start the BLE application and it starts advertising.After a set time of 1 minute the application has to c...
Jeremiah by Associate II
  • 1288 Views
  • 0 replies
