STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
Resolved! Read Characteristic attribute issue
I'm trying to achieve a simple characteristic read from a client device on a STM32WB55 to a server device on a STM32WB35on client side - after connecting I get a HCI_LE_CONNECTION_COMPLETE_SUBEVT_CODE and I keep track of connection_handle in a grobal...
oga by Associate III
  • 1175 Views
  • 1 replies
Resolved! Bluetooth company ID Registration
We are developing a product using the STM32WB55 chip and using the S.T W.P.A.N stack. We intend to release our product with a Bluetooth certification / logo, so we need to register our company to get a company I.D right ? Do we need to use the compan...
Resolved! STM32WB05KZ Antenna Power Configuration
Dear I hope you are doing well.I would like to confirm if the default antenna power of the STM32WB05KZ board is set to 0 dBm ?  Additionally, could you please guide me on how to modify this power setting?Thank you in advance for your support. I look ...
ljm by Associate III
  • 707 Views
  • 1 replies
Chip antenna VS PCB anetnna
HelloI have a question, please. I am planning to use a Bluetooth module, and since I am required to apply potting, could you let me know which antenna is less affected by it: the chip antenna or the PCB antenna?thanks
  • 728 Views
  • 1 replies
Resolved! Zigbee application stuck at M0 callback
Hi!I am trying to reproduce some examples and got stuck at simple sensor.The example code is working fine on my P-Nucleo-wb55, but if I am trying to reproduce i with CubeMX i've got failedCode is simply stuck at void shci_cmd_resp_wait(uint32_t timeo...
_Garacio_ by Associate II
  • 2559 Views
  • 3 replies
  • 1 kudos
Resolved! BLE Project with Personalized Services (Central device)
Hi,I'm currently working on a project using multiple B-WB1M-WPAN devices:one acts as BLE Central;the others act as BLE Peripherals.I'm using the STM32_WPAN software package in CubeMX 6.14.My question is: how do I create a Central that is able to inte...
cvlt by Associate II
  • 2274 Views
  • 4 replies
  • 1 kudos
