STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Test Framework
Hi TouchGFX team,I'm in dire need of a test framework for my TouchGFX projects, and I've heard that you already make use of an internal version that allows you to step through a program frame by frame. That would be really useful!Do you plan on relea...
Örjan by Associate
  • 4447 Views
  • 3 replies
  • 1 kudos
TouchGFX BoxWithRoundedCorner and Border
 Hi Team,I hope this message finds you well. I wanted to inquire if the TouchGFX team has any plans to introduce a BoxWithRoundedCorner widget in TouchGFX Designer.I’ve created a custom implementation on my end, but managing multiple widgets has prov...
TouchGFX build fails
when i run on touchgfx but with cubeide when i build there isn't error : gcc/makefile_cm7:503: recipe for target 'CM7/TouchGFX/build/Riverdi_70STM32H7/CM7/TouchGFX/target/generated/TouchGFXGeneratedHAL.o' failedmake[3]: *** [CM7/TouchGFX/build/Riverd...
Aziz by Associate II
  • 1758 Views
  • 3 replies
Framebuffer shifts across the screen in runtime
I am using similar hardware to the stm32f469i-disco however the screen is a st7701 and is ran in video mode (burst mode) with double buffer.I have added a video below showing the issue, for context the framebuffer doesn't shift with quick interaction...
JSime.1 by Associate II
  • 2517 Views
