STM32 MCUs Motor control
Discuss STM32 solutions for motor control, including PID tuning, sensorless operation, ADC noise, custom algorithms, and more.
User Manual MCSDK documentation
  Dear MCSDK users, The full MCSDK documentation is embedded in the Motor Control Workbench tool. Refer to Workbench tool > About > Documentations > Documentation.This document provides: Introduction: Includes startup guide links for MCSDK, HSO featu...
GMA by ST Employee
  • 1735 Views
  • 0 replies
MCSDK 6.4.0 is out!
Dear MCSDK users, MCSDK version 6.4.0 is now available: Download It here. This version of the new Motor Control SDK 6 series (X-CUBE-MCDSK) provides mainly FOC and 6Step improvements, here are the main changes for this version: Motor Control Features...
GMA by ST Employee
  • 4881 Views
  • 0 replies
  • 3 kudos
Board Manager documentation is out !
The documentation of the Board descriptions format is now available on Motor Control Boards Description Wiki page, this documentation is compatible with MCSDK versions from 6.1.2. Board Descriptions are used by the ST motor-control workbench to enabl...
Zied b. by ST Employee
  • 9579 Views
  • 5 replies
  • 3 kudos
PWM signal randomly dropping.
I'm working with an STM32L552ZET6Q and two DRV2605L vibration motor drivers (Adafruit breakout board version. Link to chip datasheet below). https://www.ti.com/lit/ds/symlink/drv2605l.pdf?ts=1683119643574&ref_url=https%253A%252F%252Fwww.google.com%25...
_legacyfs_online_stmicro_images_0693W00000bjJzzQAE.png _legacyfs_online_stmicro_images_0693W00000bjK0EQAU.png
ESpra.1 by Senior
  • 3812 Views
  • 4 replies
Resolved! b-g431b-esc1 current sensing clarification
I want to understand the current sensing that is done in B-G431B-ESC1 kit. I do not understand the purpose of IN_VOPAMP3 connected to ADC2The opamp3 can be connected to ADC1 and ADC2 as shown in the figure? The software configuration of opamp3hopamp3...
SRedd.5 by Senior III
  • 4578 Views
  • 9 replies
  • 1 kudos
Resolved! MC_DURATION Fault in B-G431B-ESC1 software
I am getting the fault of MC_DURATION after running for few seconds in my customized board but software is same as B-G431B-ESC1. I am not sure why this error is happening, any advise? I have changed the REGULATION_EXECUTION_RATE to 2 from 1 assuming ...
  • 1583 Views
  • 4 replies
BLDC switching sequence from PWM to GND
Hi all,I am working on BLDC motor control using Hall sensors. At the moment, the motor seems to be running fine, however, I have noticed something strange in one of the sequences (this can be seen in the attached image taken from an oscilloscope). Wh...
adromo95 by Associate II
  • 1080 Views
  • 0 replies
Resolved! Active low LIN Mosfet driver and software changes.
I am using the software of b-g431b-esc1 and the driver used in the board as per schematics is in my board the micro is RB series but the problem is with the Mosfet driver which has an active low signal, IR2108What changes do i need to make in the sof...
_legacyfs_online_stmicro_images_0693W00000biyXCQAY.png _legacyfs_online_stmicro_images_0693W00000biyXlQAI.png
  • 2208 Views
  • 5 replies
Resolved! Motor Profiler stuck on "Checking ST-Link connection"
I'm trying to use the Motor Profiler software through my Motor Controller SDSK 6.1.1. When I launch the profiler, I Select my boards - Nucleo-F302R8 and X-Nucleo-IHM07M1 3Sh. Then I set the motor parameters to match my motor Bull Running BR2804. When...
_legacyfs_online_stmicro_images_0693W00000bj8tCQAQ.png _legacyfs_online_stmicro_images_0693W00000bj8tHQAQ.png _legacyfs_online_stmicro_images_0693W00000bj8tMQAQ.png _legacyfs_online_stmicro_images_0693W00000bj8t8QAA.png
ABart.5 by Associate II
  • 3043 Views
  • 4 replies
