It is not clear where the value of SPEED_LOOP_FREQUENCY_HZ is defined.
AndrewSibiryack
Hi!
Help!
When creating a position control project in the MC SDK using NUCLEO-F446RE and X-NUCLEO-IHM08M1-3Sh when compiling to KEIL, an error occurred.
Thank you in advance!
VFerr.2
Replace by POSITION_LOOP_FREQUENCY_HZ in all files. It's a bug.
4 REPLIES 4
VFerr.2
AndrewSibiryack
Thanks! Everything worked out!
Thanks @VFerr.2​ for sharing the solution.
@cedric H​ , could you please take care to implement the fix?
-Amel
Hello @Amel NASRI​
This is a known issue already handled in the following thread
Cedric
