STM32 MCUs Motor control
Discuss STM32 solutions for motor control, including PID tuning, sensorless operation, ADC noise, custom algorithms, and more.
User Manual MCSDK documentation
  Dear MCSDK users, The full MCSDK documentation is embedded in the Motor Control Workbench tool. Refer to Workbench tool > About > Documentations > Documentation.This document provides: Introduction: Includes startup guide links for MCSDK, HSO featu...
GMA by ST Employee
  • 1734 Views
  • 0 replies
MCSDK 6.4.0 is out!
Dear MCSDK users, MCSDK version 6.4.0 is now available: Download It here. This version of the new Motor Control SDK 6 series (X-CUBE-MCDSK) provides mainly FOC and 6Step improvements, here are the main changes for this version: Motor Control Features...
GMA by ST Employee
  • 4881 Views
  • 0 replies
  • 3 kudos
Board Manager documentation is out !
The documentation of the Board descriptions format is now available on Motor Control Boards Description Wiki page, this documentation is compatible with MCSDK versions from 6.1.2. Board Descriptions are used by the ST motor-control workbench to enabl...
Zied b. by ST Employee
  • 9578 Views
  • 5 replies
  • 3 kudos
6 Step Sensored MC SDK 6 Issues
Devkit: (B-G431B-ESC1)Motor: (Pole pair = 3, (6 total magnets))Hall Sensor: Honeywell SS41F, 40 mechanical degree placement and 120 electrical (odd mechanical placement due to 3 pole pair)Software: MC SDK V6.I am trying to use 6-step sensored control...
Resolved! How to drive the high-side of the bridge in STSPIN32F0?
Hi all,I am new to motor control, and I am currently working with the BLDC motor driver board STEVAL-SPIN3201 (based on the STSPIN32F0). I am trying to generate the corresponding PWM signals to drive a BLDC motor. Although the low side of the bridge ...
adromo95 by Associate II
  • 1295 Views
  • 1 replies
Resolved! How do you set up sensored six-step control? (in a kit, that supports it, but doesn't have an example file for it)
I'm building a project around the B-G431B-ESC1 board, that claims to support hall sensored 6-step control, but in motor bench there are no example files for this (only sensorless electric speed control files). I know you are supposed to generate file...
Resolved! Help setting the comparator for the timer brake. Internal connection between the comp and TIM1 with complementary outputs
Hi, I'm setting up a custom board with STM32G431CBT6 to control a 6-step bldc motor. I want to use comparators to protect against overcurrent.My problem I configured the bkin input and comparators. the bkin input works, the comparator also works sepa...
_legacyfs_online_stmicro_images_0693W00000bid4IQAQ.png _legacyfs_online_stmicro_images_0693W00000bid4NQAQ.png _legacyfs_online_stmicro_images_0693W00000bid4SQAQ.png _legacyfs_online_stmicro_images_0693W00000bid4XQAQ.png
MGrod by Associate II
  • 2205 Views
  • 1 replies
Resolved! STSPIN32G4 random gatedriver or timer1 output shutdown
Hello I am using a custom design with the STSPIN32G4. Running open loop space vektor commutation works, but after a random amount of time the motor simply stops.Surprising is that if SPI is active the error seems to occure sooner than normal. Everyth...
DWiec.1 by Associate
  • 2353 Views
